Mac, VM XP Pro, Cisco VPN, and Printing.
I have an end user running a Mac with a VM XP Pro Machine that connects to our corperate VPN. This part works just fine. The problems come up when he tries to print to a local network printer. The job just sits until he disconnects from the VPN and then it prints just fine. Does anyone know what to do to fix this? I have little or no MAC knowledge.
Dan
1 ACCEPTED SOLUTION
Silver
Re: Mac, VM XP Pro, Cisco VPN, and Printing.
That could be the reason why printing is not working. The printing traffic is actually going to vpn tunnel as split tunnel is not configured.
Silver
You can check if split-tunnel is enabled or not. If not then enable it .
Saju
Pls rate helpful posts
Trying to stay away from split tunnel.
Silver
That's what I figured but I hoped someone would have dealt with this in the past and have a work around other than split tunneling.
Dan
Split tunnel look sto be the only option.
124
