Man 0/0 on Standby ASA - speed/duplex
I noticed the hard coded speed and duplex settings for interface Management 0/0 do not replicate from the primary to the standby ASA. Do I have to manually hard code these on the secondary? Will the settings keep after the unit restart since it gets its config from the primary?
We are using this as the failover interface.
Re: Man 0/0 on Standby ASA - speed/duplex
I know that Cisco suggests that you dont use the Managment interface for your failover interface... but thats another issue all together. If you use the montior-interface command on Managment it should provide you with some more information (not positive but its worth a shot)
Cheers,
Chris
I ended up hard coding the speed/duplex on the standby ASA. This appears to have fixed the problem. Even after restating, the settings stayed.
115
