Community Member
Managment IP for firewall
how to set the management ip for a firewall say like we have a loopback int for router,switch..
Re: Managment IP for firewall
Hello aksher@cisco,
You can't configure a loopback on a Pix. Why doesn't one of the interface addresses work for you? What are you trying to accomplish?
Hope this helps! If so, please rate.
Gold
Aksher
If you are talking about accessing PDM (PIX Device Manger for management) via VPN from a remote site then yes this can be accomplished.
If want to run the PDM from your internal LAN, then again this can also be accomplished.
If you want to connect to the PIX via SSH then this also can be accomplished.
But NO you can not setup loopback addresses on the PIX.
So, which of the above method are you asking for?
Jay
100
