Mapping an address from dmz to inside?
I have a client router that I have no control over that I want to put in my DMZ and give it access to only 1 device on the inside network. I'm having a mental block on how to make this happen. I already have static (inside,dmz) for the server this router needs to be able to get at listed below.
static (inside,DMZ) 172.23.4.2 as400 netmask 255.255.255.255 0 0
how can I let this router in the dmz also access the as400?
1 REPLY
Gold
Re: Mapping an address from dmz to inside?
Hi -
Hope the following example helps your situation:
Pix(config)# global (outside) 1 200.200.200.10-200.200.200.253 netmask 255.255.255.0
Pix(config)# nat (inside) 1 0 0
Pix(config)# nat (dmz) 1 0 0
Pix(config)# static (dmz,outside) 200.200.200.1 192.168.5.5
Pix(config)# static (inside,dmz) 192.168.5.0 192.168.5.0 netmask 255.255.255.0
Pix(config)# access-list no_nat permit ip 192.168.2.0 255.255.255.0 192.168.5.0 255.255.255.0
Pix(config)# access-list no_nat permit ip 192.168.3.0 255.255.255.0 192.168.5.0 255.255.255.0
Pix(config)# nat (inside) 0 access-list no_nat
Pls. Remember the rule: From Interface Inside to Interface DMZ requires nat/global command.And DMZ to Inside requires static/conduit. Pls. issue cmd: 'clear xlate' after configuration has been saved with cmd: 'wr m' (write memory)
Thanks -
88
