Mapping drives automatically using WebVPN client
Situation: One of my client uses SSL VPN in tunnel mode (which installs a small client application on the PC) to connect to his office network. There is no problem in getting VPN connection. It is actually after the fact that he wants to access his network drives (which are automatically mapped when logs in to the domain when connected to the LAN). He can access the network drives by manually mapping to the respective network folder. We use SecureACS with RSA for authenticating the users connecting via VPN.
Question: Is there a method by which we can automatically map the network drives when the users connect via VPN and disconnect them once the user disconnects VPN?
Any help and ideas are greatly appreciated.
DEAN WETHERALD
Did you manage to resolve this issue??? If so can you provide some info???
Dean
Unfortunately, we could not resolve this. We ended up providing a batch file to the users that would map the drives after the users connect via VPN.
Thanks for the update.
If I find anything I'll post it.
Dean
