You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
mapping external IP to internal for FTP and other services
This should be so simple but I cannot get this to work. I am trying to map an external IP to a server on the network. I have the ACL and static statements in place but still can't connect from the outside. I have a feeling that some NAT statement somewhere is still blocking access. If anyone can offer some advice on this issue it would greatly be appreciated. Attached is my current config. Thanks in advance for any assistance.
  • Other Security Subjects
Re: mapping external IP to internal for FTP and other services
Just modify access-list outside_in , so that the source of the traffic is any and the destination is host 69.153.241.34.
It would look like this:
access-list outside_in permit tcp any host 69.153.241.34 eq ftp
access-list outside_in permit tcp any host 69.153.241.34 eq www
access-list outside_in permit tcp any host 69.153.241.34 eq 2401
If you are still having issues after making the above change, I would also make sure that the PIX's default gateway (router at 69.153.241.33) , doesn't have an inbound acl on it's wan interface.
That worked!! I knew it was something simple that I was overlooking. Thanks a bunch!!
149
