Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
MARS Installation errors - beep codes
Hi all,
I'm imaging a 100E with 4.2.1, newly purchased had 3.x on it, and I'm getting an error beep code when I get to the "making disks" part.
I get 2 quick beeps - pause - 4 quick beeps.
Now, if I reboot the box, the beeps start immediately. I reseated the disks and power supplies, no change.
The install doesn't fail, or stop (from what I can tell) it seems to be writing to the disks - as evidenced by the led's flashing.
Any suggestions?
I've tried installing the recovery image disk that it came with, but the same thing happens.
Bob
1 REPLY
Re: MARS Installation errors - beep codes
Per Cisco:
"Root cause of 2 beeps followed by 4 beeps is as follows.
This has been debugged by the hardware team and has been determined to be caused due to backwards fan assembly."
Resolution:
Return the box for a new one.
Bob
117
