Community Member
MARS - reporting device identification
When one is running a QUERY/REPORT in MARSv4.3 how can I go about identifying which reporting device is generating the events? I have several devices pumping logs to the MARS but I can't seem to tell which one is generating which event.
For example -
I run a query against all Event Types ranked by Sessions for the last 10 minutes. I submit in-line. The results are sorted etc but I can't figure out how to drill down and see which IP is causing the event.
1 ACCEPTED SOLUTION
Community Member
Re: MARS - reporting device identification
If you run a query on the individual event, it will show you the reporting device
Community Member
any ideas?
Community Member
Community Member
Thanks for the response. It works
103
