max number of Ethernet interface supported on 6.2(2)
Good morning,
I have a pix 525 UR with Pix 6.2(2) version. I am fingind any confirmation about the maximum number of physical interface supported. I think they are 10, but I found confirmation of it in the 7.0(1).
Is it the same case for the 6.2(2)?
Any link to confirm it in the CCO?
Re: max number of Ethernet interface supported on 6.2(2)
Hi Macardell
You can see the maximum number of interfaces with the command "Show ver"
This command returns as following:
...... (omited output)
Maximum Physical Interfaces:3
Maximum Interfaces: 5
The Maximum Physical Interfaces is the number of phisical interfaces, and Maximum Interfaces includes virtual interfaces.
I hope this can help you.
Best Regards
Roberto
Have you got any link that can confirm it?
If I do not have the card still I cannot really check it.
Is the output you got from a 525 UR?
It is a command you can use in any platform and any version.
Here you have the link you requested.
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2120/prod_release_note09186a00801a6d21.html
I put the output for PIX 525UR.
Roberto
101
