MIBs with IPSEC
gareth.grocott
I have a router using 10+ VPNs and need to monitor when each one goes down. There was an experimental MIB : enterprises.9.10.62.1.2.3.1.1.8.7.82.111.117.116.101.114.66
The values 0 = done and 2 = up
but the versions dont seem to have this. Can anyone help?
jreekers
Level 4
Level 4
hi gareth.
Could you please tell me what type of router, and what IOS version is running on it?
Also, I think the MIB locator might be useful to you:
http://tools.cisco.com/ITDIT/MIBS/servlet/index
HTH,
-Joe
Hi Joe
IOS is 12.3(11r)T2 and its a 3845 Router
Gareth
Hi Gareth.
This mib should have what you're looking for:
CISCO-IPSEC-FLOW-MONITOR-MIB
This is the MIB object that shows the # of tunnels:
cikeGlobalActiveTunnels OBJECT-TYPE
SYNTAX Gauge32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"The number of currently active IPsec Phase-1 IKE Tunnels."
::= { cikeGlobalStats 1 }
http://ftp.cisco.com/pub/mibs/v2/CISCO-IPSEC-FLOW-MONITOR-MIB.my
Using the MIB Locator tool, which you can find here:
you should see that this MIB is supported on the 3845.
HTH,
-Joe
