Community Member
Mismatched attr types for class .....
Hi there,
I am using Cisco VPN Client 3.5.2 to VPN to a 3005 Concentrator that is setup authenticate externally through MS IAS server. The problem happens Sometimes when I VPN, the VPN client shows:
"Initializing the connection...
Contacting the gateway at 12.151.151.10...
Authenticating user..."
Then I fill in the username and password then the client sits on "authenticating users" for a while.. and it either completes the VPN Process or sometimes it terminates saying connection terminated by peer... Why is it taking that long to authenticate? And why is it failing with the IKE proposals?
Here is the debug log (I can't post it all because of the limitation on the message size)
Part of the debug shows:
22344 07/30/2003 12:27:33.790 SEV=8 AUTHDBG/2 RPT=125 AUTH_Close(979)
22345 07/30/2003 12:27:33.790 SEV=9 IKEDBG/0 RPT=10590 12.100.100.67 Group [groupHS] processing IKE SA
22346 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10591 Proposal # 1, Transform # 1, Type ISAKMP, Id IKE Parsing received transform: Phase 1 failure against global IKE proposal # 1: Mismatched attr types for class Hash Alg: Rcv'd: SHA Cfg'd: MD5
22349 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10592 Phase 1 failure against global IKE proposal # 2: Mismatched attr types for class Hash Alg: Rcv'd: SHA Cfg'd: MD5
22351 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10593 Phase 1 failure against global IKE proposal # 3: Mismatched attr types for class DH Group: Rcv'd: Oakley Group 2 Cfg'd: Oakley Group 1
22353 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10594 Phase 1 failure against global IKE proposal # 4: Mismatched attr types for class DH Group: Rcv'd: Oakley Group 2 Cfg'd: Oakley Group 1
22355 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10595 Phase 1 failure against global IKE proposal # 5: Mismatched attr types for class DH Group: Rcv'd: Oakley Group 2 Cfg'd: Oakley Group 7
22357 07/30/2003 12:27:33.790 SEV=8 IKEDBG/0 RPT=10596 Phase 1 failure against global IKE proposal # 6: Mismatched attr types for class Hash Alg: Rcv'd: SHA Cfg'd: MD5
22359 07/30/2003 12:27:33.790 SEV=7 IKEDBG/28 RPT=37 12.100.100.67 Group [groupHS] IKE SA Proposal # 1, Transform # 2 acceptable Matches global IKE entry #
and
22412 07/30/2003 12:27:41.710 SEV=8 AUTHDBG/67 RPT=4 AUTH_TimeOut(1d756c8, 0, 0)
22413 07/30/2003 12:27:41.710 SEV=9 AUTHDBG/75 RPT=4 Reply timer expired: handle = 9E5F0029, timestamp = 611882323
22414 07/30/2003 12:27:41.710 SEV=8 AUTHDBG/64 RPT=204 AUTH_StartTimer(1d756c8, 0, 0)
22415 07/30/2003 12:27:41.710 SEV=9 AUTHDBG/73 RPT=203 Reply timer started: handle = 9E5F0029, timestamp = 611882323, timeout = 4000
22416 07/30/2003 12:27:41.710 SEV=8 AUTHDBG/62 RPT=203 AUTH_SndRequest(1d756c8, 0, 0)
22417 07/30/2003 12:27:41.710 SEV=8 AUTHDBG/31 RPT=190 Radius_Decode(1c35384, 90)
22418 07/30/2003 12:27:41.710 SEV=8 AUTHDBG/28 RPT=97 Radius_Xmt(1d756c8)
22419 07/30/2003 12:27:41.710 SEV=9 AUTHDBG/71 RPT=199 xmit_cnt = 2
22420 07/30/2003 12:27:42.700 SEV=6 IKE/0 RPT=5 12.100.100.67 Group [groupHS] User [maher] Duplicate Phase 2 packet detected!
22421 07/30/2003 12:27:42.700 SEV=6 IKE/0 RPT=6 TM received unexpected event EV_START_XAUTH in state TM_START
22422 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/30 RPT=111 Radius_Match(1d756c8, 1be5284), id = 0x3E, rcvd = 0x3E
22423 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/63 RPT=211 AUTH_RcvReply(1d756c8, 0, 0)
22424 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/31 RPT=191 Radius_Decode(1be5284, 88)
22425 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/29 RPT=91 Radius_Rcv(1d756c8)
22426 07/30/2003 12:27:45.610 SEV=9 AUTHDBG/32 RPT=72 Radius: Discarding unknown Vendor Specific Attribute: vid = 311, type = 7
22427 07/30/2003 12:27:45.610 SEV=9 AUTHDBG/32 RPT=73 Radius: Discarding unknown Vendor Specific Attribute: vid = 311, type = 8
22428 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/66 RPT=194 AUTH_DeleteTimer(1d756c8, 0, 0)
22429 07/30/2003 12:27:45.610 SEV=9 AUTHDBG/74 RPT=193 Reply timer stopped: handle = 9E5F0029, timestamp = 611882713
22430 07/30/2003 12:27:45.610 SEV=8 AUTHDBG/58 RPT=194 AUTH_Callback(1d756c8, 0, 0)
22431 07/30/2003 12:27:45.610 SEV=6 AUTH/4 RPT=36 12.100.100.67 Authentication successful: handle = 980, server = 172.16.10.39, user = maher
1 REPLY
Community Member
Re: Mismatched attr types for class .....
Here is another debug log that happened when the VPN Client reported the connection was terminated by remote peer. The user I am using is MAHER and the IP Address I am using is 12.151.129.13. The IAS servers IP Address is 172.16.10.39. It seems that COncentrator can't locate the IAS sometimes!
40426 07/30/2003 14:30:52.350 SEV=6 IKE/0 RPT=8 12.151.129.13 Group [groupHS] User [maher] Duplicate Phase 2 packet detected!
40427 07/30/2003 14:30:52.350 SEV=6 IKE/0 RPT=9 TM received unexpected event EV_START_XAUTH in state TM_START
40428 07/30/2003 14:30:53.070 SEV=8 IKEDBG/0 RPT=19712 204.210.200.3 RECEIVED Message (msgid=bb644786) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 76
40430 07/30/2003 14:30:53.070 SEV=9 IKEDBG/0 RPT=19713 204.210.200.3 Group [groupHS] User [ecote] processing hash
40431 07/30/2003 14:30:53.070 SEV=9 IKEDBG/0 RPT=19714 204.210.200.3 Group [groupHS] User [ecote] Processing Notify payload
40432 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/67 RPT=7 AUTH_TimeOut(1dddf98, 0, 0)
40433 07/30/2003 14:30:55.320 SEV=9 AUTHDBG/75 RPT=7 Reply timer expired: handle = A09D0027, timestamp = 612621684
40434 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/57 RPT=3 AUTH_Error(1dddf98, 0, 0)
40435 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/15 RPT=2 AUTH_MgmtServerOffline(e5b2bc, 8949820)
40436 07/30/2003 14:30:55.320 SEV=4 AUTH/15 RPT=3 Server name = 172.16.10.39, type = RADIUS, group = groupHS, status = Not-in-service
40438 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/66 RPT=296 AUTH_DeleteTimer(1dddf98, 0, 0)
40439 07/30/2003 14:30:55.320 SEV=9 AUTHDBG/74 RPT=295 Reply timer stopped: handle = A09D0027, timestamp = 612621684
40440 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/58 RPT=296 AUTH_Callback(1dddf98, 0, 0)
40441 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/60 RPT=294 AUTH_UnbindServer(1dddf98, 0, 0)
40442 07/30/2003 14:30:55.320 SEV=9 AUTHDBG/70 RPT=294 Auth Server e5b2bc has been unbound from ACB 1dddf98, sessions = 0
40443 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/59 RPT=318 AUTH_BindServer(1dddf98, 0, 0)
40444 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/57 RPT=4 AUTH_Error(1dddf98, 0, 0)
40445 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/58 RPT=297 AUTH_Callback(1dddf98, 0, 0)
40446 07/30/2003 14:30:55.320 SEV=4 AUTH/9 RPT=2 12.151.129.13 Authentication failed: Reason = No active server found handle = 26, server = 172.16.10.39, user = maher
40448 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/4 RPT=164 AUTH_GetAttrTable(26, 73d0d8)
40449 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/2 RPT=196 AUTH_Close(26)
40450 07/30/2003 14:30:55.320 SEV=4 IKE/167 RPT=3 12.151.129.13 Group [groupHS] User [maher] Remote peer has failed user authentication - check configured username and password
40452 07/30/2003 14:30:55.320 SEV=4 IKEDBG/68 RPT=8 12.151.129.13 Group [groupHS] User [maher] IKE TM V6 FSM error history (struct &0x1c2e87c) , : TM_DONE, EV_ERROR TM_AUTH, EV_AUTH_FAIL TM_AUTH, NullEvent TM_AUTH, EV_RESEND_MSG
40455 07/30/2003 14:30:55.320 SEV=4 IKEDBG/65 RPT=9 12.151.129.13 Group [groupHS] User [maher] IKE AM Responder FSM error history (P1 struct &0x1ee99e4) , : AM_FREE, NullEvent AM_PROC_MSG3, EV_TEST_V6 AM_PROC_MSG3, EV_DSID_OK AM_PROC_MSG3, NullEvent
40458 07/30/2003 14:30:55.320 SEV=9 IKEDBG/0 RPT=19715 12.151.129.13 Group [groupHS] User [maher] IKE SA AM:d1caaf88 terminating: flags 0x0105c001, refcnt 0, tuncnt 0
40460 07/30/2003 14:30:55.320 SEV=9 IKEDBG/0 RPT=19716 sending delete message
40461 07/30/2003 14:30:55.320 SEV=9 IKEDBG/0 RPT=19717 12.151.129.13 Group [groupHS] User [maher] constructing blank hash
40462 07/30/2003 14:30:55.320 SEV=9 IKEDBG/0 RPT=19718 constructing delete payload
40463 07/30/2003 14:30:55.320 SEV=9 IKEDBG/0 RPT=19719 12.151.129.13 Group [groupHS] User [maher] constructing qm hash
40464 07/30/2003 14:30:55.320 SEV=8 IKEDBG/0 RPT=19720 12.151.129.13 SENDING Message (msgid=e9763269) with payloads : HDR + HASH (8) + DELETE (12) total length : 76
40466 07/30/2003 14:30:55.320 SEV=8 AUTHDBG/10 RPT=196 AUTH_Int_FreeAuthCB(1dddf98)
40467 07/30/2003 14:30:55.320 SEV=7 AUTH/13 RPT=196 Authentication session closed: handle = 26
40468 07/30/2003 14:30:56.890 SEV=8 IKEDBG/0 RPT=19721 151.199.25.199 RECEIVED Message (msgid=36406dd4) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 76
40470 07/30/2003 14:30:56.890 SEV=9 IKEDBG/0 RPT=19722 151.199.25.199 Group [groupHS] User [camelot\bcverniero] processing hash
40471 07/30/2003 14:30:56.890 SEV=9 IKEDBG/0 RPT=19723 151.199.25.199 Group [groupHS] User [camelot\bcverniero] Processing Notify payload
40472 07/30/2003 14:30:57.370 SEV=6 IKE/38 RPT=4 12.151.129.13 Header invalid, missing SA payload! (next payload = 8)
537
