Community Member
Missing context for signature 5081
I have two sensors running on the same level. One records the context for signature 5081 the other only the event without any more informations.
For example:
4,1220191,2002/09/30,19:12:36,2002/09/30,19:12:36,10008,20300,908,OUT,IN,4,5081,0,TCP/IP,XXXXXXXXXXXXX,XXXXXXXXXXXXX,412
3,80,0.0.0.0,/system32/cmd.exe,474554202F736372697074732F2E2E25323535632E2E2F77696E6E742F73797374656D33322F636D642E6578653F2F632B64697220485454502F312E300DZZ
(GET /scripts/..%255c../winnt/system32/cmd.exe?/c+dir HTTP/1.0)
the other system does record only
4,1006597,2002/09/18,05:19:17,2002/09/18,05:19:17,10008,201
00,908,OUT,IN,1,5081,0,TCP/IP,XXXXXXXXX,XXXXXXXXX,4636,80,0.0.0.0,/system
32/cmd.exe
We need this information, because we include it in our daily reports, just to see if somebody is only probing (dir...) or tries something else. Is there any switch / parameter that is controlling the recording of context information ? I checked the settings within the .SizWizMenu program, and both maschines are using the same definitions.
Re: Missing context for signature 5081
Please describe each sensor, model #, software version, Sig Update version.
There is no switch to turn it on. It should be there. Are the two sensors Identical? (i.e. both 4230's running 3.1.3 S32 )
There is not a switch in packetd, but there is one for loggerd.
Try looking in loggerd.conf for the token MinContextLevel.
Normally this is set to 2 so level 2 alarms and higher will have their Context logged, but if you accidentally changed this to 5 then your level 4 alarm being generated will not have it's Context information logged in the sensor log file.
Community Member
Great - the event level was below of the MinContextLevel. I adjusted it and voila its working.
Thank you very much...
Peter
124
