Monitor Total Bytes Recieved and Sent
corey.borton
I am setting up a hub and spoke vpn with a 515 and 5 506's and I need to be able to monitor the total bytes recieved and sent to and from the 515 for billing purposes. Can anyone suggest any easy way to keep track of these counters. we only use windows operating systems eg W2K.
p.krane
Level 3
Level 3
You can use the show interface command, refer the following doc
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml#showinterface
But another option is try using MRTG which will give you a graphical representation of your usage.
For more details check the following URL
http://people.ee.ethz.ch/~oetiker/webtools/mrtg/
