Community Member
Monitoring VPN accelator card
We have a Cisco 7140-2FE router with one VPN accelator card. We'd like to monitor this card using the following command:
router#sh crypto engine accelerator statistic [cardID]
However when typing this command no result is returned. Does anyone have a clue what the reason ca be?
IOS version: Version 12.2(11)T8
The card is working properly:
router#sh crypto engine bri
crypto engine name: Unknown
crypto engine type: hardware
CryptIC Version: 0xFF41
CGX Version: 0x0111
DSP firmware version: 0x0065
MIPS firmware version: 0x03062700
ISA/ISM serial number: ###
PCDB info: ###
Compression: No
3 DES: Yes
Maximum buffer length: 4096
Maximum DH index: 1014
Maximum SA index: 2029
Maximum Flow index: 4059
Maximum RSA key size: 2048
crypto engine in slot: 4
crypto engine name: unknown
crypto engine type: software
serial number: ###
crypto engine state: installed
crypto engine in slot: N/A
Community Member
Re: Monitoring VPN accelator card
Hi, if I remembered correctly, the "sh crypto eng acc stat" command only works for AIM modules for the 26xx/36xx/37xx routers. I had not learnt the command that shows the same information for ISA/ISM modules in the 7100/7200 series router yet.
If anybody knows how to get ISA/ISM statistics, please advise.
Community Member
we have learned in the meantime from Cisco to use the following command set on 71xx routers having a VPN accelator card installed:
sh pas isa ?
controller show controller
interface show interface
