01-08-2007 02:00 AM - edited 02-21-2020 02:48 PM
I have to implement a VPN with four routers every router has different configurations but the Primary router has only one interface connected to internet. When ever I try to implement more than one VPN on the same interface it gives me an error that u have a VPN running on this interface and it can be effected ,ignoring this error will cost me VPN down from previous site.
Solved! Go to Solution.
01-08-2007 04:50 AM
You need to use the same crypto map, with different priority values (10 for first site-to-site, 20 for the second), as only one crypto map can be applied on a given interface.
Please rate if this helped.
Daniel
01-08-2007 04:50 AM
Daniel
