MPLS Aware IPSec VPN using SPA-IPSEC-2G
Question everyone on a strange problem,
I just setup up a configuration running MPLS aware IPSec VPN using an SPA-IPSEC-2G module,
If I from the internal interface, try to ping the remote end, of the VPN tunnel, there is no problem, then I add a router on the backend of the central VPN router, connected direct to the same IP subnet, the backend router, is not able to ping the inside interface of the central VPN router, when removing "crypto map TEST" its possible to ping between Backend and Central VPN,
Tried to put on an access-list on the interface,when "crypto map" is off, the access-list counts up, when adding the "crypto map" nothing happens on the access-list,
[backend] 172.31.110.128/28 [Central VPN] 131.x.x.64/28 [@] 131.x.x.252/30 [Remote VPN] 172.31.110.1 [loopback]
Configuration is don by using interface Vlan ,
Any hints,
Best regards
Peter
1 REPLY
Silver
Re: MPLS Aware IPSec VPN using SPA-IPSEC-2G
crypto map should not be applied to an interface if there is a entry with no match address defined.
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a00804d35a6.html
108
