MTBFs, No. of Rules and a bit more
Hi Guys,
Would like to know the following for all the PIX platforms. Can anyone help?
1) MTBF figures,
2) No. of new sessions per second
3) Max No. of Rules
Finally, does Version6.3 support email notification to a pre-defined email address in case of a security alerts and is this configurable to occur at a specific logging level?
Vito
Re: MTBFs, No. of Rules and a bit more
All, applogies for reposting this message. A partial reply to any of the questions would be very helpful.
Vito
Answers Inline
1) MTBF figures,
>> Still trying to figure out
>> We will treat this question as max number of connections
PIX515R/UR = 64K/125K
PIX525 = 250K
PIX525 = 280K
PIX535 = 500K
Note: I may not be 100% correct, but you can easily get the number of connections supported on CCO web site.
http://www.cisco.com/warp/public/cc/pd/fw/sqfw500/index.shtml
3) Max No. of Rules
>> you mean ACLs?
>>Nope, there is no such support. but you can get this support from your syslog server.
Nadeem
Thanks Nadeem.
Regarding question 3, yeah max no. of ACLs is what I meant.
Max number of entries for ACL, depends on the amount of RAM you have.
From this link
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb721.html#1034390
The TurboACL feature requires significant amounts of memory and is most appropriate for high-end PIX Firewall models, such as the PIX 525 or PIX 535. The minimum memory required for TurboACL is 2.1 MB and approximately 1 MB of memory is required for every 2000 ACL elements.
Just to give you some idea.
Nadeem
Hi Nadeem, Again thanks for looking at this. Unfortunately I don't have access rights to view the above link. I don't have partner access, and just "guest" access. Is this document also available for guest logins?
Vito
This site requires a login, but i have cut/paste what was relevant and important for you.
Nadeem
Thanks Nadeem,
Where did you cut/paste it too? It wasn't attached to your message.
Vito
Nadeem,
Really sorry to bother you again with this. Can you cut/paste again or send the whole document to me at v-molinaro@gol.com
Thanks mate
Vito
I am not 100% again, this just a rough idea
predicted MTBF of 414,600 for the PIX-525.
The MTBF on the 520 was about 60,000 hours
Hi Nadeem,
Any MTBF figure for PIX501, 506, and 515 or 515E ?
Appreciate for any insight info.
Best Regards,
Engel
145
