Multiple 3002-3060 connection with same user password
I would like to know if it's possible to setup mutiple simutanous 3002-3060 connection with the same user password
thanks
1 REPLY
Re: Multiple 3002-3060 connection with same user password
Yes, you can. VPN 3002 similar like the software client, can connect simutanous with same username and password.
Make sure the Simultaneous Logins not over the numbers you set in VPN 3000 concentrator end:
Configuration | User Management | Users | Modify cisco
"general" TAB,
"Simultaneous Logins" numbers.
Best Regards,
79
