Multiple mGRE spoke tunnels from 1 device to the hub possible ?
Is it possible to configure more mGRE spoke tunnels from 1 device possible to the same hub device?
10.0.0.0-R-spoke -------- R-hub-11.0.0.0
1 mGRE
This would allow loadsharing over multiple paths from the R-spoke to the R-hub
or do you have to configure more mGRE tunnels between the 2 devices to make this work?
Kind regards,
Renaat Leuridan
Bronze
Re: Multiple mGRE spoke tunnels from 1 device to the hub possibl
The ability to configure two mGRE tunnels with same tunnel source on one router already exists as a feature request (bug CSCea16812). You can track the same and see where it goes.
Thanks for the reply, but is it also possible to configure from 1 router-spoke a mgre tunnel to 1 destination address, but with differnt source ip addresses (of the parallel connected physical interfaces towards the hub) ?
110
