Community Member
multiple outside IP addresses to one inside
Can the ASA support more than one outside ip address to one inside via the Static command ?
can not get it to work, atleast not in my first try.
Re: multiple outside IP addresses to one inside
Hi .. it depends if you are using different ports you should be able to use port redirection otherwise it is not possible as static is a one to one mapping. What you could do thought is to add a secondary IP address to your internal host and create another static map for that second address ...
I hope it helps ... please rate if it does !!!
Community Member
Yes that was what I suspected
just wanted to confirm that there was no way to do this for the same port
regards
Arni
112
