Multiple VPN clients through same source IP
My situation is that I need to let multiple VPN clients connect from the same source IP address. I have a small office that connects to a 3000 concentrator from a PIX 501 (not lan to lan) which will have the same source address, and initially, my 3000 concentrator wont let that happen. I get an error about multiple connections from the same IP - refused. Is there any way I can get around this?
1 REPLY
Re: Multiple VPN clients through same source IP
Think about using IPSEC over TCP. The default setting for VPN clients is UDP. it may also work if you set the NAT UDP options.
The doc's will tell you how to set this up.
88
