Multiple vpn configuration help
Hi everyone,
I need help because I have to configure a router...I need to create lan-to-lan vpn,to create dynamic vpn and to configure the router to accept connection made with the vpn client software.I think that I should use "profiles",but I can't get the router work fine.Lan-to-lan vpn are OK,but I can't have dynamic vpn AND vpn client connections working fine (only one of the two).
  • Other Security Subjects
1 REPLY
Bronze
Re: Multiple vpn configuration help
103
