My pix has a hole !!!
I have a small problem with the PIX firewall and it is a small one
just want to see if I can get your grey cells to work along with
mine to resolve this small issue.
I have a Windows 2000 server which is also a oracle server for one of our clients. The live IP address of the server is 194.219.44.195 mapped to static internal 192.168.0.3 . This is for sql access from the outside.
What happens is , if I am using the internt connection from say
my home R any where else outside,and I click on Start > Run and then
type in the Open box //194.219.44.195 and click on open,after some time it comes out with No Network Connection found.This is the same with Windows 95, R windows 98 R windows NT workstation.
If I try the same with another windows 2000 professional R windows 2000 server which has internet connection, Then surprisingly
the shared folders of the server open up !!!! Amazingly the server is just open.
Could you please let me know any such issues whith windows 2000 what is to be done on the server side , what ports to be blocked R anything that will resolve this issue with my client , R he will have me for Lunch this week end :).
Thanx
Tauseef
delvidubai@yahoo.com
config :
nameif ethernet0 outside security0
nameif ethernet1 inside security100
interface ethernet0 auto
interface ethernet1 auto
ip address outside 194.219.44.196 255.255.255.192
ip address inside 192.168.0.1 255.255.255.0
arp timeout 14400
mtu outside 1500
mtu inside 1500
nat (inside) 1 192.168.0.0 255.255.255.0
global (outside) 1 194.219.44.200-194.219.44.205
global (outside) 1 194.219.44.206
logging on
logging timestamp
no logging standby
logging console debugging
logging monitor debugging
logging buffered debugging
logging trap debugging
no logging history
logging facility 23
logging queue 512
access-list acl_in permit icmp any any
access-list acl_in permit tcp any any eq www
access-list acl_out permit icmp any any
access-list acl_out permit tcp any host 194.219.44.194 eq smtp
access-list acl_out permit tcp any host 194.219.44.194 eq pop3
access-list acl_out permit tcp any host 194.219.44.194 eq domain
access-list acl_out permit tcp any host 194.219.44.195 eq sqlnet
route outside 0 0 194.219.44.193 1
static (inside, outside) 194.219.44.194 192.168.0.2 netmask
255.255.255.255 0 0
static (inside, outside) 194.219.44.195 192.168.0.3 netmask
255.255.255.255 0 0
access-group acl_in interface inside
access-group acl_out in interface outside
Re: My pix has a hole !!!
don't know a lot of how win2k trys to access shared drives, win95 etc use udp ports eg 138,139 netbios etc. Try taking out the
command. That should only allow an outside host to ping the inside host. Nothing else should be allow in.
Also don't know if it grammatical or just an error
but your access group statement is wrong it should have an "in" statement. Otherwise it won't be applied to the interface. (I think)
hope it helps
Thanx candy,
but the "in" was just missing in the config put up , but it is implemented there in , in the real scenario.Well the access-list acl_in permit tcp any any eq www was essential to allow the internal LAN computers to browse any web site outside using only port 80,well that is essential for the LAN computers to be able to browse the internet,right....
well IM still on the run for this solution,but am sure will get it and will post it when I get the right fix for the solution,Till then take care,and have a nice time.
bye
tauseef
You shouldn't allow your internal servers to initiate a www sesion with anything on the outside. Change your access list to only allow clients to initiate http traffic.
73
