Mysterious SSH2 password's problem
For the last couple of days I have been trying to solve a great ssh2 mystery for my switch ws2950 (ver 12.1(22)ea13):
I put:
(config) Username tadas password cisco
But after show run I get: username tadas password 0 cisco
So the question is: why do i get password 0 cisco  ? And in fact none of my (0 cisco or just cisco) passwords works for logging into switch via ssh2. I am using Tera Term Web 3.1 Though i don't have any problem to connect via com1.
Thank you for your help.
1 REPLY
Re: Mysterious SSH2 password's problem
In your command, you didn't tell the router to encrypt the password. Something like this would correct that~
username tadas secret cisco
You could also enable password hashing in the config (it does not change the password, only encrypts them for config viewing) using service password-encryption
To view the password in plain text, simply remove the command and you will see the password again. For higher security, use the 1st command above.
Hope that helps.
211
