Community Member
NAC and NAP
What is the items needed to start using NAC on a network? As far as what routers are supported and are there any servers needed to run software and the clients, etc?
Re: NAC and NAP
Check out these FaQ's. It answers your query,
http://www.cisco.com/en/US/products/ps6128/products_qanda_item0900aecd802da200.shtml
Please rate if helps
~JG
Community Member
Re: NAC and NAP
Ok that does answer a lot of questions. The main one I have while I wait for my rep to contact me is this. If we purchase the NAC manager http://www.cisco.com/en/US/products/ps6128/index.html Do we need an independent server to run anything or is that box that is going to run everything.
Re: NAC and NAP
You need both CAM and CAS.
Clean Access Manager (CAM)?The administration server for Clean Access deployment. The secure web console of the Clean Access Manager is the single point of management for up to 20 Clean Access Servers in a deployment. For out-of-band deployment, the web admin console also provides Switch Management capability.
?Clean Access Server (CAS)?Enforcement server between the untrusted (managed) network and the trusted network. The CAS enforces the policies you have defined in the CAM web admin console, including network access privileges, authentication requirements, bandwidth restrictions, and Clean Access system requirements. It can be deployed in- band or out-of-ban.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/ciscosec/cca/cca36/cam36ug.pdf
~JG
371
