Community Member
NAC Appliance and LDAP Lookup
I have two CAM in HA and two CAS in HA.
I configure the LDAP Lookup for create rule to role allocation.
In this configuration are only one windows server to make find the user properties.
There are one problem when this Windows servers is down. There are any configuration to mitigation when the server is not there.
Thank you all.
1 ACCEPTED SOLUTION
Re: NAC Appliance and LDAP Lookup
The LDAP lookup server configs state it uses the LDAP Authentication Provider. The LDAP Authentication Provider says you can have multiple entries in the single field
LDAP
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/413/cam/m_auth.html#wp1158614
You can add redundancy for LDAP Authentication servers by entering multiple LDAP URLs in the Server URL field separated by a space, for example:
ldap://ldap1.abc.com ldap://ldap2.abc.com ldap://ldap3.abc.com
Community Member
I believe that in version 4.5.0 you can add more than one LDAP look up server. Of course to get to 4.5.0 you must be running on the "appliance" hardware according to Cisco.
Community Member
Thank you,
I will review the 4.5 documentation.
LDAP
Community Member
Thank for you answer. For me will usefully this feature and resolve the problem.
139
