Community Member
NAC Appliance w/ Load Balancing
Hello.
I am looking for examples of the NAC Appliance with load balancing. Either with CSS boxes or an ACE module. For example, can you do load balancing in L2 virtual gateway mode? Are there examples anywhere? I cannot find any.
Thanks if anyone can help out!
1 REPLY
Community Member
Re: NAC Appliance w/ Load Balancing
...nobody has done this before? I've been doing research and am curious to see if with a Cisco ACE module, you can do load balancing with the CAS servers in virtual gateway mode. It seems possible (with the mac-sticky command on the ACE), but (what little docs are out there) points to the ACE in routing mode and the NAC in Real-IP mode.
Any input...?
138
