NAC CAM/CAS Temporary Certificate expired
Hello Guys,
I have a high availability pairs of NAC(CAM/CAS), Last 3 months I generate temporary certificate and now it is expired.
Do I need to generate again a new temporary certificate and delete the old one? Is there any certificate that can give me lifetime certificate?
3 ACCEPTED SOLUTIONS
Re: NAC CAM/CAS Temporary Certificate expired
Please review this document detailing how to generate certificates for longer terms:
https://supportforums.cisco.com/docs/DOC-11889
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Yes, you can issue certs for a century if you'd like.  :-) For ten years, put in 3650 as the number instead of 1000
HTH,
Faisal
Yes, 4.8 has been out for a bit now. Download it here: http://bit.ly/dwaXlc
Release notes, including the new features, the bug fixes and the upgrade instructions for 4.8 are here: http://bit.ly/9inkeW
HTH,
Faisal
HTH,
Faisal
Hello Faisal,
thanks as always as you are precise, i see in the document that the certification can be used for 1000 days? is it possible that I can changed it for example 10 years?
thank you and best regards
HTH,
Faisal
Hello Faisal,
Is NAC version 4.8 is released? If it is already released so I can upgrade my NAC version 4.7 to 4.8?
1. How can I upgrade my NAC to 4.8? Is there any procedures for this?
thanks
HTH,
Faisal
Hello Faisal,
I already generate openssl for longer terms, my question is how can i import it to my HA CAM and HA CAS? What I saw in my X509 Certificate is the temporary certificate and I need it to be replaced by my openssl certificate. I mean
Anyways, thanks for the link of version 4.8 I already upgraded my NAC to version to version 4.8.
1174
