NAC In-Band Deployment for Wireless and VPN
I am trying to configure In Band VG for Wireless and VPN users. I have already configured the NAC for wireless users. My switch configuration for Wireless as follows :
nterface GigabitEthernet6/25
description NAC Server (IB - WLAN) - Trusted Intf ETH0
switchport
switchport trunk native vlan 997
switchport trunk allowed vlan 100,200,400,692
switchport mode trunk
interface GigabitEthernet6/26
description NAC Server (IB - WLAN) - UnTrusted Intf ETH1
switchport
switchport trunk native vlan 996
switchport trunk allowed vlan 616-618
interface Vlan692
description NAC SRV (IB) Management VLAN
ip address 10.1.6.25 255.255.255.248
My question is what I need to create on the switch for VPN users? I appreciate your expert help.
Re: NAC In-Band Deployment for Wireless and VPN
You will implement VPN as you would without CAS. The important element is the private side of the VPN is the untrusted side of the CAS.
Review these documents:
Integrating with Cisco VPN Concentrators
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/45/cas/s_vpncon.html
CCA Chalk Talks
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5707/ps8418/ps6128/prod_presentation0900aecd80549168.html
You can deploy NAC in-band mode for wireless use a WLC, if so which paper do you recommend for doing
Another question, can be integrated in a scheme using Wireless OOB NAC with Single Sign On(RAdius Server), as documents said that some details (using an option similar to that used with VPNs), but others say no, if it is possible that documentation you can provide me, thanks
one last question in a LAN environment using NAC OOB Virtual Gateway mode is supported Single Sign On?
Juan,
Yes, that is supported.
HTH,
Faisal
That is the answer to which of my questions? Of which is not because I made you 3 questions, not whether it can be a bit more specific
Juan,
Sorry. Should have been more specific. I was answering for the query you had: "one last question in a LAN environment using NAC OOB Virtual Gateway mode is supported Single Sign On?"
HTH,
Faisal
  I had a doubt about the implementation of NAC because NAC OOB desire to implement a wired network using Cisco switches and a wireless network in a single WLC using CAS, it is possible and advisable to do this implementation, if so there is some guidance?
Hi faisal, had other questions in a nac vpn implementation in VG band or Real Ip gateway is possible to place an L2 switch between Cisco ASA and CAS?
Espero que tu ayuda, gracias.
794
