NAC IN BAND - VIRTUAL GATEWAY - L2L TRAFFIC BYPASS
TIAGO MATIAS
Hello Everybody
I have a solution where i implemented the NAC IN BAND - VIRTUAL GATEWAY with a CVPN 3000 to perform a compliance for VPN Remote Access.
I  need  BYPASS the LAN-TO-LAN traffic , where can i configure the networks that are used for LAN-TO-LAN VPN for bypass the NAC or to NAC ignore this networks ?
Faisal Sehbai
Level 7
Level 7
Tiago,
If they're coming from a specific subnet, you can put them in the filters to not NAC. Click on Filters on the CAM gui
HTH,
Faisal
Faisal, i added the subnets in  DEVICE MANAGMENT ==> FILTERS ==> SUBNETS but i think that is not OK
Is necessary configure the CCA SERVER ==> ADVANCED ==> MANAGED SUBNETS  too ? and about the " unauthenticated role "  is necessary configure the subnets here too ?
