NAC L2 802.1x (wireless)
Can somebody advice me - where i can find information about configuring NAC L2 802.1x on wireless AP 1200 series? Or can somebody show me example of configuration file? I have found configuration guide only about wired solutions (configuring NAC L2 IP and NAC 802.1x on switch).
Thank you in advance!
Bronze
Re: NAC L2 802.1x (wireless)
For NAC implementation with wireless access points, the implementation is the same as the switch wired Layer 2 802.1x implementation for network admission control. The only difference is that you will need to use a third party NAC-enabled supplicant such as Meetinghouse for your wireless devices.
sample config on AP
aaa new-model
aaa authentication eou default group radius
aaa session-id common
radius-server host 10.100.100.100 auth-port 1645 acct-port 1646
radius-server key cisco123
radius-server vsa send authentication #Enable VSAs
ip radius source-interface FastEthernet0/0
ip admission name NAC-L2-IP eapoudp #Define NAC policy
ip admission name NAC-L2-IP-Bypass eapoudp bypass #
ip admission name NAC-L3-IP eapoudp1 list EoU-ACL #Define NAC trigger, routers only
ip access-list extended EoU-ACL
deny udp any any eq domain #allow DNS to bypass NAC
deny tcp any host 10.100.100.101 eq www #allow HTTP to bypass NAC
permit ip any any #all other traffic triggers
ip access-list extended Interface-ACL
permit udp any any eq 21862 #permit EAPoUDP
permit udp any eq bootpc any eq bootps #permit DHCP
Refer these links:
http://www.cisco.com/en/US/netsol/ns617/netbr0900aecd80355b2f.html
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a0080606cbe.html#wp1072071
Thank you for the answer!
Unfortunalety, "ip admission" command is not recognized by the AP IOS.
IOS version 12.3(7)JA4
bootloader 12.2(8)JA
is there any suggestions? :)
271
