NAC-L2-IP on 3550 Switch
I am trying to configure NAC-L2-IP on a 3550 Switch running "IP-Base" software and version 12.2(25)SED.
According to NAC Phase 2 documentation, this is a supported feature on 3550 switches with the above version.
I am able to create the admission rule, however when i apply it to the interface, I get the below error
sam(config)#ip admission name mynac eapoudp
sam(config)#int fa0/32
sam(config-if)#ip ad
sam(config-if)#ip admission mynac
% This config is not supported on this platform. Try configuring a new rule.
Any ideas ?
Naman
Re: NAC-L2-IP on 3550 Switch
Solved my own issue..!
Had to change the switchport mode to "access" from "dynamic".
Naman
You need to upgrade your IOS to the 12.2(25) IP SERVICES.
@rodrigo
nope, it also worked with ipbase-12.25
for the exactly ipbase version, i used:
ipbasek9-mz.122-25.SEE
just for info
224
