NAC problem. Cant add server.
Andrey Chubakov
Hi all!
I cant add a nac server to CAM. Error: Failed to add server: Conflicting Clean Access Server with IP address <10.52.244.146> must first be removed.
I add server with ip: 10.52.244.194. I checked all the settings. This address is not use in the settings of server whit IP - 10.52.244.146.
In the logs I dont see useful information.
Why do I have this error on the CAM???
Jennifer Halim
You might be hitting this bug: CSCtd27095
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtd27095
Please follow the "workaround" advised in the bug.
Jennifer Halim
Andrey Chubakov
Thx, Jennifer. I found this bug in Release Notes for Cisco NAC Appliance.
Jennifer. In CSCtd27095 says: The repair updates only the CAS file locally. The fix/repair should update the CAM's database with the CAS's new SSKey. I reconfigure perfigo service with right SSkey on my CAS (10.52.244.194). Does not help. I cant reconfigure perfigo on my CAM, because 10 servers in work.
P.S.
When i delete CAS with IP 10.52.244.146, then i can add CAS (10.52.244.194). But when i just change CAS IP - 10.52.244.194 on, for example, 10.52.244.154 anyway i see this error.
What create a conflict of these servers?
Yup, unfortunately you would need to update the CAM DB with the right SSkey to resolve the issue.
