05-04-2010 05:35 AM - edited 02-21-2020 10:24 AM
I configured my NAC in L3OOB, if I connect my pc directly to the switch I don't have any problem, I can access the network as out of band user, I can pass the authentication. BUT IF I CONNECT a Cisco ip phone to the switch and my pc is connected to the Cisco ip phone I am stacked to the authentication vlan and cannot access the network. The event logs of my CAM is say it detects multiple mac address.
Please guys help me to solve this issue..
thank you and best regards.
Solved! Go to Solution.
05-04-2010 06:40 AM
Did you add your phone's MAC address to your CAM in the IGNORE filter?
Faisal
05-04-2010 06:40 AM
Faisal
05-04-2010 09:07 AM
just now i added it to my cam and check again but still same problem. i am implementing L3OOB. Do I need to configure also the CAS? I don't have exact procedure? Please do you have guidelines so that i wont be guessing?
thank you very much..
05-05-2010 05:03 AM
I just wonder, the Cisco Clean access agent always pops-up for username and password even I am already authenticated and in OUT of band.
Please how can I eliminate or remove the pop-up if I am already accessing the network?
thank you and best regards,
