NAC Stub Agent options for 4.7
Does anybody knows if Cisco is providing a substitute option for the role of the NAC Stub Agent  in version 4.7?
Thanks.
1 ACCEPTED SOLUTION
Re: NAC Stub Agent options for 4.7
Dennis,
The service is installed as part of the agent installation. Agent installation now requires admin rights.
HTH,
Faisal
Dennis,
Stub's been replaced with a service. You need admin rights to install it, but for later updates, you don't need admin rights. Most of the functionality of stub is now in the service.
HTH,
Faisal
Ok,
And how do I install this service? Where is that documented?
Thank you.
Dennis,
HTH,
Faisal
351
