NAC Wireless WLC L2 OOB Deployment
Hi all,
        I would like to know if the, OOB deployment for NAC is tied to the SSID or vlan?
In my enviroment i have a few different SSID with the same vlan, i'm trying to test out my NAC deployment without affecting prodution SSID. I would like to find if i can turn on NAC per SSID or it will have to be per Vlan?
1 REPLY
Re: NAC Wireless WLC L2 OOB Deployment
Adrian,
Currently it's one Auth VLAN mapped to one Access VLAN. You could theoratically put more than one SSID on the same VLAN, but I would test it thouroughly before deploying in production.
HTH,
Faisal
307
