NAC with EV SSL certs
BEN ROBINSON
Does anyone know if the NAC appliance supports EV SSL certs; especially version v4.7.x.
Any insight into older versions (4.1.3 and higher) for compatibility would be appreciated. Thanks!
ben
Faisal Sehbai
Level 7
Level 7
Ben,
Not familiar with those. What's the difference between the EV certs and a regular SSL cert?
Faisal
Apparently a few things but notably for the NAC the CSR has a stronger key (1024 bit and higher).
Ben,
Higher key lengths shouldn't be a problem. Any other pertinent data points?
Faisal
Hello! The higher key length is a problem on an older version (4.1.3), not 4.7.x; etc where you can specify it. 4.1.3 you cannot specify it and it's not strong enough.
Ben
