NAT 0 problem with VPN
We have the following problem:
PIX 520 5.3.3
Three interfaces
- outside 10.x.x.x
- dmz 172.16.x.x
- inside 172.17.x.x
VPN termination ( PPTP ) 192.168.100.x
An internal host 172.17.1.1 is published with a static to 10.1.1.1
External clients which connect via VPN ( PPTP ) should be able to connect to the internal host ( with internal IP ) only to a specific port.
We have configured a NAT 0 for inside and associated to it a access-list wich permit ip to the host .
then we created an access-list applied to the outside wich should permit only the port requested .
The problem is that it seems the outside access list is ignored and all traffic is permitted from VPN client to the internal host
Following part of config
nameif ethernet0 outside security0
nameif token-ring0 inside security100
nameif ethernet1 bondioli security99
name 172.17.1.1 ASSAP
name 10.1.1.1 ASSAP-PUB
access-list 101 permit ip host ASSAP 192.168.100.0 255.255.255.0
access-list from-inside permit ip host ASSAP any
access-list from-inside deny ip any any
access-list from-outside permit icmp any any echo-reply
access-list from-outside permit tcp any host ASSAP-PUB eq 3201
access-list from-outside permit tcp any host ASSAP-PUB eq 3203
access-list from-outside deny ip any any
ip local pool VPN-IP-POOL 192.168.100.1-192.168.100.254
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) ASSAP-PUB ASSAP netmask 255.255.255.255 0 0
access-group from-outside in interface outside
access-group from-inside in interface inside
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe 40
vpdn group 1 client configuration address local VPN-IP-POOL
vpdn group 1 client authentication local
Re: NAT 0 problem with VPN
Hello
Your access-list from-outside couldn´t match your requirement, because the packet from the vpdn client to the internal server are adressed to the outside adress of the pix. The source adress is the official vpdn client ip address and the destination address is the outside ip address of the pix at the time the packet arrives on the outside interface of the pix. The pix decapsulate the packet and then foreward it out the internal interface.
Your solution is to permit only the wanted return traffic in the from-inside acl.
access-list from-inside permit tcp host ASSAP eq 3201 192.168.100.0 255.255.255.0
access-list from-inside permit tcp host ASSAP eq 3203 192.168.100.0 255.255.255.0
This should meet your requirements.
Michael
Michael ,
thanks for your replay , we'll try your suggestion immediately .
However the configuration we made was based on the example in the cisco documentation
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v53/config/commands.htm#xtocid78
In the command reference of vpdn command there's the example we started from
We tried your tip but got no luck
It seems that when enabling the Nat (inside) 0 access-list ... packets bypasses the acl on the outside interface
77
