NAT and Lock&keyDynamics Access lists
Any know whether NAT & Dynamic Access lists (lock&key) can be used together?
I'm trying to allow authenticated inbound access via port 3389 accross a NAT'ed 12.2 1721.
I can get NAT to work & I can get lock&key to work, but not both together.
Re: NAT and Lock&keyDynamics Access lists
Yikes! Not really sure about the answer here but I am hoping to be able to talk you out of Lock and Key. Any chance you can use a feature we call Auth-Proxy instead? This was developed to replace Lock and Key. To be honest, we have done little or no development on Lock and Key in a long time and you will also have a hard time finding many TAC engineers that remember this feature ;)
Take a look at the following sample config for some info on Auth-Proxy and NAT combined:
http://www.cisco.com/warp/public/793/ios_fw/auth6.html
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t5/iosfw2/iosfw2_1.htm
Well
The sample deployments of auth proxy I've looked at all seem to require a separate tacacs+ or radius server, and a lot of statements. All I'm looking for is a single authenticated (local) login that would allow external access with windows terminal services (3389) to a single server.
The lock & key dynamic access list concept allowed that to happen with 3 statements with a local username.
OK. You do not *need* a AAA server to do Auth-Proxy but I can't imagine this feature scaling very well without one. However, I guess I cannot argue with the ease of configuration. So, back to the orginal question. Can you elaborate a bit more on exactly what is not working with respect to Lock and Key and NAT? What are you NAT'ing? Perhaps a sanitized config will help a little...
Scott
Scott
I'm actually working off the 12.0 IOS security book & a TAC authored technote "Lock&Key:Dynamic Access lists" dated 3/12/03. The conf with both nat & L&K set is:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 1720R
logging queue-limit 100
enable secret 5 $1$e.UL$sfQWgNqbf8HLjmfdY/OMj.
username testuser password 0 123456
memory-size iomem 15
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 10.1.1.1 255.255.255.0
ip nat inside
speed auto
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
bandwidth 2000
ip address 200.2.2.1 255.255.255.0
ip access-group 120 in
ip nat outside
clockrate 2000000
ip nat inside source list 10 interface Serial1 overload
ip nat inside source static tcp 10.1.1.10 3389 200.2.2.1 3389 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 200.2.2.2
no ip http server
access-list 10 permit 10.1.1.0 0.0.0.255
access-list 120 dynamic testlist timeout 10 permit ip any any
access-list 120 permit tcp any host 200.2.2.1 eq telnet
line con 0
exec-timeout 0 0
password red
logging synchronous
login
line aux 0
line vty 0 4
login local
autocommand access-enable timeout 5
end
After I telnet to the router and authenticate:
1720R#sh access-lists
Standard IP access list 10
permit 10.1.1.0, wildcard bits 0.0.0.255 (85 matches)
Extended IP access list 120
Dynamic testlist permit ip any any
permit ip any any (106 matches) (time left 23)
permit tcp any host 200.2.2.1 eq telnet (54 matches)
1720R#
At this point, I can't wts into the host, but the outbound access is OK. When the dynamic ACL times out, then outbound access disappears.
The problem is that the client is a remote non-profit with a single server, few users and little cash.
Thanks for noticing this.
JC
Ok
Problem solved. enabling CBAC on the inside interface made this work as expected. The unexpected issue is that you can no longer telnet into the firewall itself. Oh well...
191
