NAT and PAT
Scenario:
US Private Network--Router--US NAT Router--Router--Phil Private Network
IP Addressing
US Private Network: 172.16.100.0/16
Inside Global: 192.168.1.1/27
Phil Private Network: 172.16.200.0/16
Inside Global: 192.168.10.1/28
Question:
1. Is it possible to ping the US private network from Phil private network, and vice versa.
2. Can you provide me a sample config in all router?
3. if i create an acl for translation. and create again for limiting the tcp and udp port, would it create any conflict?
Kindly help me on this. Thanks
1 ACCEPTED SOLUTION
Bronze
Re: NAT and PAT
hi
did you mean subnet mask 16 or 24!!!
(I supposed that you are using IOS routers)
in the case of mask 16 you are in the same network 172.16.0.0 bad design and you will be dealing with overlapping network.
so go ahaed and implement nat-overlapping (IMPLEMENT ip NAT INSIDE AND ip NAT OUTSIDE FOR EACH SITE) SO In this case you solve the problem of making both networks able to communicate,to ping a host in the other site you dont know witch translated address corespond to wicth real address unless you have configured one-to-one mapping static nat .
in the case of 24 you are in diffrent network
no problem go ahead and implement normal nat.
for question 3 the answer is :
* for ip nat inside the access-list is applied BEFORE translantion .
and for ip nat outside the access-list is applied AFTER translantion .
so i assumed that there is no conflict if the access-list addresses the correct networks.
kamal
1 REPLY
Bronze
Re: NAT and PAT
hi
kamal
218
