NAT Config Help
I've inherited a PIX 520 running 6.3(5). It has four network interfaces; outside, dmz, dmz2, and inside. I would like to have all traffic from interface dmz2 to be NAT'ed with a different IP address than the other interfaces (so I can QoS it at my border router).
The PIX is currently configured as below; from my reading, it looks like the two global commands for the two dmz interfaces are incorrect. Can somebody verify please?
global (outside) 1 63.xxx.xxx.230
global (dmz) 1 192.168.107.227 netmask 255.255.255.0
global (dmz2) 1 192.168.108.227 netmask 255.255.255.0
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 0 access-list nonatdmz
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz2) 1 0.0.0.0 0.0.0.0 0 0
access-list 101 permit ip 10.5.0.0 255.255.0.0 10.6.60.0 255.255.255.0
access-list nonatdmz permit ip 192.168.107.0 255.255.255.0 10.6.60.0 255.255.255.0
I think I will need to change/add the following:
nat (dmz2) 2 0.0.0.0 0.0.0.0 0 0
and
global (dmz2) 2 63.xxx.xxx.231
1 REPLY
Re: NAT Config Help
Yes.. you can use different NAT identifier as you mentioned above for your dmz2 subnet and this should do the job for you.
To verify that translation is done correctly, apply "debub icmp trace" command and initiate a ping from dmz2 to outside and see how translation is working.
Best of Luck,
Haitham
103
