nat-control
Hi all,
I had 3 security zone, outside , dmz and inside.
I did static nat for dmz server ip nat to inside ip (from low security to high security.
static (DMZ,Inside) 10.1.1.25 202.187.108.25 netmask 255.255.255.255
static (DMZ,Inside) 10.1.1.26 202.187.108.26 netmask 255.255.255.255
From inside user PC (10.1.1.100) to access to the DMZ server, basically we connect to ip 10.1.1.25 or 26.
But it seem like not work if the nat-control is enable. Why ?
Re: nat-control
with no nat-control in place, pix is acting as a router firewall, not needing any nat rule. hence you see it working.
see what error message you are getting in your log.
i think you also need nat from inside to dmz interface
e.g.
nat (inside) 1 0 0
global (dmz) interface
or
static (inside,dmz) insideip insideip
Re: nat-control
Thanks problem solved.
Curious about this problem, when STATIC from high security to low security we do not need to NAT it. Why low security to high security we need it ? make no sense.
Many Thanks
Re: nat-control
with nat control on, you have to have nat or static
from higer to lower. lower to higher nat is not a requirement by design unless you want to specifically do nat
122
