Nat from outside to inside PIX 515-E - 6.3(4)
I am pretty new with PIX (version 6.3) and I am trying from my PC in outside (192.168.0.2) to ping the inside interface (10.35.121.98) or any host in the inside.
Here is my configuration, I do not understand why it is not working.
- I authorized icmp on both interface
- I put an access-list on the outside interface.
- I created a static translation between outside and inside interface.
: Written by enable_15 at 10:38:55.840 UTC Tue Jul 11 2006
PIX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pix
domain-name goeland.intra
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol icmp error
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list permitall permit icmp 192.168.0.0 255.255.0.0 10.35.0.0 255.255.0.0
access-list 101 permit icmp host 192.168.0.2 host 10.35.121.98
pager lines 24
logging on
logging trap debugging
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 192.168.0.1 255.255.255.0
ip address inside 10.35.121.98 255.255.255.128
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.0.2 10.35.121.100 netmask 255.255.255.255 0 0
access-group permitall in interface outside
route inside 10.35.0.0 255.255.0.0 10.35.121.98 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.35.0.0 255.255.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
: end
My PC gateway is 192.168.0.1 and I never see a hitcount on access list permitall but I see the icmp packet exit my PC. From the PIx, I can ping muy PC (connected with the console).
Thanks for your help.
Best regards,
Romain
Re: Nat from outside to inside PIX 515-E - 6.3(4)
From your PC can you ping 10.35.121.100? That is what your static translation is setup for.
I cannot ping this adress.
I also tried to translate to 10.35.121.98 => Not OK
With ethereal, when pinging 10.35.121.98, I see the ping exit from 192.168.0.2 but nothing occurs on the PIX (I activated "debug icmp trace" and "debug packet outside"). When pinging 192.168.0.1 from 192.168.0.2, the ping is OK.
I can ping the 192.168.0.2 from the PIX (console connection).
Best regards,
Romain
Your static command is actually translating 10.35.121.98 to 192.168.0.2. I don't believe this is what you are trying to do. If you want to have your outside source appear as a different IP follow the NAT Outside documentation. Attached below.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html#wp1113519
Ultimately what you are trying to do is allow internal addresses be access by an external. What you should use is a Policy NAT 0 with an access-list. This will avoid the Xlate requirement for your outside host but still have Xlates for other apps.
Here is a sample configuration (I have something similar in production).
access-list Outside_Host permit ip host 10.35.121.98 host 192.168.0.2
! next statement is more general but you could make it more subnet specific
access-list Outside_Host permit ip any host 192.168.0.2
nat (inside) 0 access-list Outside_Host
Please rate any helpful posts
Fred
Hi .. your static sentence ...
is making 10.35.121.100 appearing as 192.168.0.2 to the outside network. So if you want to reach to the inside device from the outside network you have to ping 192.168.0.2 the destination will be redirected ( NATed) by the PIX to 10.35.121.100 .. Is this what you are trying to achieve ..? or do you want to be able to reach 10.35.121.100 directly ( Without NATing ) ..?
If you want to reach 10.35.121.100 directly then you need to bypass NAT ..
nat (inside) 0 access-list NO_NAT
nat (outside) 0 access-list NO_NAT outside
acccess-list NO_NAT permit icmp 192.168.0.0 255.255.0.0 10.35.0.0 255.255.0.0
acccess-list NO_NAT permit icmp 10.35.0.0 255.255.0.0 192.168.0.0 255.255.0.0
I hope it helps .. Please rate if it does !!!
Fernando picked up on my mistake, he's right on your current NAT statement, it's doing .100 not .98. Typo on my part. They did add the outside command in 6.3 but I've found that outside inside works with just the standard NAT 0 command using an access-list with destination subnet. I have had this working in production before the outside command was released. Either configuration should work for you. Fernando's configuration would have more validity with the TAC.
Fred
126
