NAT HELP
I trying to setup multiple subnet for the nat range using private address of 10.10.1.0-10.10.16.0 under the same NAT ID of 1.
Is this possible, or would I have to assign each subnet with a seperate Nat ID. for outside connections
1 REPLY
Re: NAT HELP
If you want to use a single NAT id, use the following command:
nat (inside) 1 10.10.1.0 255.255.240.0
nat (inside) 1 10.10.16.0 255.255.255.0
following by a global command that matches your NAT id.
92
