NAT'ing LAN to LAN tunnels on a 3000 concentrator.
Is it possible to NAT source addresses on packets from LAN to LAN connections with the 3000 concentrator?
1 REPLY
Re: NAT'ing LAN to LAN tunnels on a 3000 concentrator.
Its not possible to do Static NAT (Network address translation) on the VPN Concentrator (VPN3000), for that we will need a Router or PIX sitting on the inside of the VPN device.
This should get you going,
Hope this helps,
Aamir Waheed
Cisco Systems, Inc.
100
