Community Member
nat inside source static AND/OR inside source overload?
On an 837 IOS 12.4 I want to nat the inside source depending on the destination.
Destination 1
Internet with normal PAT overload (also with static ports for incoming smtp and web)
So far so good.
Destination 2
IPsec tunnel. Devices on the remote end of the IPsec tunnel need to also initiate connections in to the local devices.
I can get Destination 2 working with a nat inside source route-map and nat pool but of course as it's a dynamic translation the remote tunnel devices can't initiate connections in. So I need a static nat for Destination 2?
A network static for tunnelled traffic does the trick in both directions nicely. But it NATs the inside sources for ALL destinations... not so nice.
I think I need a feature like a network static but with route-map selection for fine-grained control. Does such a feature exist?
I can't see a solution for this. Can someone prove me wrong please?!
TIA
Silver
Re: nat inside source static AND/OR inside source overload?
Actually such a feature does exist and there is a solution for this.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087bac.html
I have actually done something quite similar for one of my clients. It did require some tweaks but worked out quite well.
Community Member
Yes, I had already seen this feature; it is for individual static translations. The problem is I need to translate a subnet so would need this as a NETWORK static. The document specifically states...
"Network static support is not included in this feature."
Thankyou for your response.
Silver
I had overlooked the network static requirement.
111
