Nat issue
Is this a valid usage for a nat entry.
Ip nat inside source static 6.6.6.6 4.4.4.4 extendable
Ip nat inside source static 5.5.5.5 3.3.3.3 extendable
Ip nat inside source static 2.2.2.2 4.4.4.4 extendable
Ip nat inside source static 1.1.1.1 3.3.3.3 extendable
Please Note the same Inside global address and diffent Inside local
Purple
Re: Nat issue
Hi Lirin,
That is illegazl usage. You can only map one local address to each global address. Conversely, you can map multiple inside global addresses to the same inside local address using the extendable keyword.
Pls do remember to rate posts.
Paresh
Re: Nat issue
Paresh,
Your 100% right thanks for all your help.
Lirin
113
