Community Member
NAT or ACL issue?
I have a Cisco 850 running 12.4(2) with an existing L2L tunnel to another Cisco router. I am trying to add remote access to the Cisco 850 and I'm having, what I believe, is an ACL or NAT issue. I can connect to the 850 with the VPN client and get an address from the pool, but I can not ping in the internal network. Any help is appreciated. Here is my config:
1 ACCEPTED SOLUTION
Community Member
Re: NAT or ACL issue?
Your NAT ACL 101 needs to deny IP from internal IP to remote VPN pool 10.2.199.x.
Community Member
Community Member
Palomoj,
Thanks, that has me pointed in the right direction. I can know get replies to ping, but the replies are coming from the external IP of the router, not the 10.203.0.0 devices I am pinging on the LAN. Any more suggestions? Thanks again.
Community Member
config t
access-list 111 permit ip 10.203.0.0 0.0.0.255
any
crypto isakmp client configuration group doctors
acl 111
Community Member
Thanks Palomoi, that did it. Your help is appreciated.
100
