NAT outside
I need to implement the NAT outside command:
I configure it in this way:
nat (outside,inside) 10.1.1.1 192.168.1.1 255.255...
where 10.1.1.1 is the address translated inside of the ousider address 192.168.1.1, so it is able to initiate a communication towards other 10.1.1.x
but it doesn't seems to function
and if I do a show xlate I don't see this entry.
where is the error?
NB: I use a Pix515 running 6.2(2)
jackko
Level 7
Level 7
you should use static command rather than nat
