NAT outside
I need to implement the NAT outside command:
I configure it in this way:
nat (outside,inside) 10.1.1.1 192.168.1.1 255.255...
where 10.1.1.1 is the address translated inside of the ousider address 192.168.1.1, so it is able to initiate a communication towards other 10.1.1.x
but it doesn't seems to function
and if I do a show xlate I don't see this entry.
where is the error?
NB: I use a Pix515 running 6.2(2)
1 REPLY
Silver
Re: NAT outside
there isn't a command that uses the format you've provided.
What you want to use is the [static] command.
static (inside,outside)
Please explain further on which intefaces the address exist. Is 10.1.1.x the inside network? Or is 192.168.1.1 the inside network? Are you attempting to translate a host on the outside or translate a host on the inside?
96
